DIST connections timing out
MattPaulissen
Post by MattPaulissen »
Here is an excerpt of the log:
WCCILdist (1), 2019.11.06 13:08:28.812, SYS, SEVERE, 39, Connection lost, Alive timeout expired, closing connection to (SYS: 6 Dist -num 1 CONN: 1) (P) @ achieveA (::1). Last message expected at 2019.11.06 13:08:28.437.
WCCOActrl (1), 2019.11.06 13:08:28.812, SYS, SEVERE, 160, Lost connection to system 6
WCCILdata (0), 2019.11.06 13:08:28.812, SYS, SEVERE, 160, Lost connection to system 6
WCCILdist (1), 2019.11.06 13:08:47.327, SYS, INFO, 4, Connected to (SYS: 6 Dist -num 1 CONN: 1) @ achieveA (::1)
WCCOActrl (1), 2019.11.06 13:08:47.499, SYS, INFO, 162, Got connection to system 6
WCCILdist (1), 2019.11.06 13:18:29.407, SYS, SEVERE, 39, Connection lost, Alive timeout expired, closing connection to (SYS: 6 Dist -num 1 CONN: 1) (P) @ achieveA (::1). Last message expected at 2019.11.06 13:18:29.329.
WCCOActrl (1), 2019.11.06 13:18:29.407, SYS, SEVERE, 160, Lost connection to system 6
WCCILdata (0), 2019.11.06 13:18:29.407, SYS, SEVERE, 160, Lost connection to system 6
WCCILdist (1), 2019.11.06 13:18:36.547, SYS, INFO, 4, Connected to (SYS: 6 Dist -num 1 CONN: 1) @ achieveA (::1)
WCCOActrl (1), 2019.11.06 13:18:36.766, SYS, INFO, 162, Got connection to system 6
WCCILdist (1), 2019.11.06 13:20:08.813, SYS, SEVERE, 39, Connection lost, Alive timeout expired, closing connection to (SYS: 6 Dist -num 1 CONN: 1) (P) @ achieveA (::1). Last message expected at 2019.11.06 13:20:08.469.
WCCILdata (0), 2019.11.06 13:20:08.813, SYS, SEVERE, 160, Lost connection to system 6
WCCOActrl (1), 2019.11.06 13:20:08.813, SYS, SEVERE, 160, Lost connection to system 6
WCCILdist (1), 2019.11.06 13:20:18.032, SYS, INFO, 4, Connected to (SYS: 6 Dist -num 1 CONN: 1) @ achieveA (::1)
WCCOActrl (1), 2019.11.06 13:20:18.220, SYS, INFO, 162, Got connection to system 6
WCCILdata (0), 2019.11.06 13:20:18.220, SYS, INFO, 162, Got connection to system 6
WCCILdist (1), 2019.11.06 13:20:57.907, SYS, SEVERE, 39, Connection lost, Alive timeout expired, closing connection to (SYS: 6 Dist -num 1 CONN: 1) (P) @ achieveA (::1). Last message expected at 2019.11.06 13:20:57.532.
WCCILdata (0), 2019.11.06 13:20:57.907, SYS, SEVERE, 160, Lost connection to system 6
WCCOActrl (1), 2019.11.06 13:20:57.907, SYS, SEVERE, 160, Lost connection to system 6
WCCILdist (1), 2019.11.06 13:21:21.798, SYS, INFO, 4, Connected to (SYS: 6 Dist -num 1 CONN: 1) @ achieveA (::1)
WCCOActrl (1), 2019.11.06 13:21:21.985, SYS, INFO, 162, Got connection to system 6
WCCILdata (0), 2019.11.06 13:21:21.985, SYS, INFO, 162, Got connection to system 6
WCCILdist (1), 2019.11.06 13:22:00.767, SYS, INFO, 39, Connection lost, MAN: (SYS: 6 Dist -num 1 CONN: 1), Connection closed
WCCILdata (0), 2019.11.06 13:22:00.767, SYS, SEVERE, 160, Lost connection to system 6
WCCILdist (1), 2019.11.06 13:22:19.923, SYS, INFO, 4, Connected to (SYS: 6 Dist -num 1 CONN: 1) @ achieveA (::1)
WCCILdata (0), 2019.11.06 13:22:20.095, SYS, INFO, 162, Got connection to system 6
WCCOActrl (1), 2019.11.06 13:22:20.095, SYS, INFO, 162, Got connection to system 6
WCCILdist (1), 2019.11.06 13:48:46.317, SYS, SEVERE, 39, Connection lost, Alive timeout expired, closing connection to (SYS: 6 Dist -num 1 CONN: 1) (P) @ achieveA (::1). Last message expected at 2019.11.06 13:48:45.926.
WCCOActrl (1), 2019.11.06 13:48:46.317, SYS, SEVERE, 160, Lost connection to system 6
WCCILdist (1), 2019.11.06 13:49:04.489, SYS, INFO, 4, Connected to (SYS: 6 Dist -num 1 CONN: 1) @ achieveA (::1)
WCCILdata (0), 2019.11.06 13:49:04.661, SYS, INFO, 162, Got connection to system 6
WCCOActrl (1), 2019.11.06 13:49:04.661, SYS, INFO, 162, Got connection to system 6
WCCILdist (1), 2019.11.06 13:49:19.379, SYS, SEVERE, 39, Connection lost, Alive timeout expired, closing connection to (SYS: 6 Dist -num 1 CONN: 1) (P) @ achieveA (::1). Last message expected at 2019.11.06 13:49:18.973.
WCCILdata (0), 2019.11.06 13:49:19.379, SYS, SEVERE, 160, Lost connection to system 6
WCCOActrl (1), 2019.11.06 13:49:19.379, SYS, SEVERE, 160, Lost connection to system 6
WCCILdist (1), 2019.11.06 13:49:27.989, SYS, INFO, 4, Connected to (SYS: 6 Dist -num 1 CONN: 1) @ achieveA (::1)
WCCILdata (0), 2019.11.06 13:49:28.176, SYS, INFO, 162, Got connection to system 6
WCCOActrl (1), 2019.11.06 14:07:49.210, CTRL, INFO, 0, , Cyclic updateUserGroups running every 60 minutes.
WCCILdist (1), 2019.11.06 14:14:47.211, SYS, SEVERE, 39, Connection lost, Alive timeout expired, closing connection to (SYS: 4 Dist -num 1 CONN: 1) (P) @ achieveA (::1). Last message expected at 2019.11.06 14:14:46.570.
WCCILdata (0), 2019.11.06 14:14:47.211, SYS, SEVERE, 160, Lost connection to system 4
WCCOActrl (1), 2019.11.06 14:14:47.211, SYS, SEVERE, 160, Lost connection to system 4
If I change the alivetimeout in the config file would it help correct this issue? These remote units are small servers that are on cellular connections, but we're above the minimum stated networking requirements by quite a bit. Are there other changes I need to make in order for them to stay connected?
Re: DIST connections timing out
Yes, with the config entry aliveTimeout in the [dist] section you can define the timeout for the dist connections.
