I have the warning "Unsupported data type 589824" in the log. but how to know what is this data type XXXXXX ?
Thanks,
Sebastien
Re: Unsupported data type 589824
Can you please copy the complete log message.
Without seeing the content of the log message we cannot identify which manager has written the log entry.
- sblancha
It comes from a UI and it is related to a dpConnect required to animate my EWO:
WCCOAui (1), 2019.10.15 08:34:12.836, CTRL, WARNING, 51, Parameter incorrect,
Module: Vision_1
Panel: C:\PVSS_projects\lhc_test\lhc_test\panels\vision\mainViews\MainLHC.pnl [LHC Vacuum]
Object: 0 named: "Layout" of type: MainViewLhc_ewo
Script: dpConnectRequest
, LhcVacNewOnlineValue, Unsupported data type 589824
Module: Vision_1
Can you please add the code snipped for the function where the problem occurred.
Maybe we can then see what the cause for the error is.
- gschijndel
sblancha wrote: ↑ Tue Oct 15, 2019 9:11 am I have the warning "Unsupported data type 589824" in the log. but how to know what is this data type XXXXXX ?
Convert the value to hex (0x00090000), search for this value in '<API_ROOT>/Libs/Basics/Variables/Variable.hxx' and find 'BIT32_VAR'.
- sblancha
Thanks, it gives me a hint.
Sebastien
Sebastien
