Event panel re-design
- walterd
It is possible to remove/hide the two drop down menu at the bottom of the panel only for the event panel ? I need them in the Alert panel.
Re: Event panel re-design
There is no standard option available to set the comboboxes invisible in the Event Screen.
If you want to hide them you have to modify the code in the references which are loaded in the Event Screen. Depending on the "screentype" you can set the objects visible/invisible.
