Syntax Analysis of WinCC OA
eraytufan
Post by eraytufan »
I'm trying to create a parser for WinCC OA Control language and I know it is similar to ANSI-C however they are not the same. There are a lot of documents about C syntax analysis, however I couldn't find any document that has a WinCC OA syntax anaysis.
Is there any document or information that I can find about WinCC OA Control language parsing and syntax analysis?
Re: Syntax Analysis of WinCC OA
A detailed documentation for the WinCC OA CTRL syntax is not available.
If you want to do a syntax check for existing WinCC OA CTRL code you can use the startup option "-syntax" for the WinCC OA UI or the CTRL command checkSyntax() in CTRL.
