I have an animation which shows and hides a sidemenu, this can be shown or hidden with a mouse click
On the same page I have a combobox, a selection point should also open the sidemenu, that means the function like a mouse click on the sidemenu
How can I trigger a script (in this case the script under "clicked") from another element with this script?
execute script clicked
- kilianvp
Re: execute script clicked
You can't do a button click via script. But you can put your code from click in a own function and call the function instead
- marcel.gay@wimag.ch
Unfortunately, this does not work because local variables are used
The script is with an animation from a button, but I want to trigger the function from a combo box on the same page
And if I change the function, I have to make sure that I do not forget the second change, with an external call eliminates this problem
How can I trigger a script (in this case the script under "clicked") from another (selected Line from Combobox) element with this script?
If you want to execute the same functions you can
-- define a library function in a CTRL library saved in scripts/libs
-- call the function at the Clicked event of the button
-- in the ComboBox when the item is selected
- gschijndel
Another option would be to:
- define an event
- connect to this event
- trigger this event
