DIST communication combined with DIST history downloading
DKuchev@croc.ru
Post by DKuchev@croc.ru »
Hello, we have an issue:
Two systems connected by DIST.
System 1 acquiring online values from System 2 at all time and offline values, for periods when DIST connection was broken.
Offline value downloading speed directly depends on online value traffic.
When online values generator generates small ammount of changes (0-1k per sec.), offline downloading speed rises up, and vise versa.
By speaking of downloading speed, I mean speed collecting offline values (by query) from remote DIST and saving them to RDB archive.
Also we found out that collecting speed from System2 much greater than writing it to System1.
Speaking of digits:
4 minutes of offline values downloading approx 24 minutes (for 5k tags) (1 200 000 values)
4 minutes of offline values downloading approx 400 minutes (for 25k tags) (1 200 000 values)
without online values traffic:
4 minutes of offline values downloading approx 7 minutes (for 5k tags) (1 200 000 values)
At the end, what parameters or what actions can we perform to speed up such processes?
our configs:
[general]
pvss_path = ""
proj_path = ""
proj_version = "3.16"
langs = "en_US.utf8"
langs = "ru_RU.utf8"
useRDBArchive = 1
defaultArchive = 99
distributed = 1
aliveTimeout = -2
maxBcmBufferSize = 100000
[ValueArchiveRDB]
oracleClientVersion = 12
DbUser = ""
DbPass = ""
Db = ""
bufferToDisk = 2
writeWithBulk = 1
queryRDBdirect = 1
queryTimeout = 60
writeTimeout = 60
SQLPreFetchCount = 15000
initialEntriesInBlock = 1000
[data]
priorityClass = 2
useLocalIdentification = 1
maxValueRequestCount = 0
maxLinesInQuery = 1000000
[dist]
distPort = 14777
messageCompression = "zlib-bzip2"
distPeer = "KHPD-WINCCOST1" 2
[event]
msgQueueHoldTime = 5
priorityClass = 2
maxInputMsgCount = 500000
msgQueueLimitTimeout = 300
fwdDp = "_RDBArchive.writingStatus.lastWrite"
fwdDp = "_RDBArchive_2.writingStatus.lastWrite"
System 2 signal generator, generates changes for 5 000 tags each second.
System 1 - 2.2Ghz 16 cores, 16Gb of RAM
System 2 - 2.2Ghz 4 cores, 4Gb of RAM
Network speed 1Gb/s
WinCC 3.16 P013
Re: DIST communication combined with DIST history downloading
I had a look at the configuration and the question is why aren't you writing data directly from System 2 into the Oracle Database?
Then there is no need to transfer all the data over the dist system.
The idea of a distributed system is that every system stores its own data and data for a remote system is only requested on demand, e.g. when opening a trend for a specific time period.
DKuchev@croc.ru
By what mechanism System 2 should write data to Oracle? Directly, using SQL Queries?
System 1 and System 2 logicaly belongs to different projects and System 1 interested only of partial tags of System 2
Little addition:
Reading time more than writing time in 3 times
If you want to store data in an Oracle database you can use the WinCC OA RDB Manager.
for details please have a look at the WinCC OA Documentation: System Management --> Database.
