• Page 1 of 1
NOertel
SVN in Gedi
Postby NOertel »
I'm installed SVN 1.12 on the Client and the Windows Explorer show via the marked Icons that my project is committed.
Furthermore I modify the Config at the installation path from WinCC. And the LogViewer does start the SVN.ctl
WCCOAui (1), 2019.09.11 16:56:39.886, CTRL, WARNING, 5/ctrl, Ort der folgenden Meldung:
Module: Gedi_1
Script: gedi/SVN.ctl
Library: C:\Siemens\Automation\WinCC_OA\3.16\scripts\libs\svnlib.ctl
Line: 110
WCCOAui (1), 2019.09.11 16:56:39.886, IMPL, WARNING, 61, Cannot open file, CtrlCB, readFromFile, C:/Users/Nico WinCC OA Server/AppData/Local/Temp/WCCOAui.oa4200 : No such file or directory
WCCOAui1:["SVN_isInstalled() FALSE"]
WCCOAui1:["SVN_isInstalled() "]
WCCOAui1:["SVN: no command line installed or project not in repository. Use -dbg SVN for more information"]
These are the details from the LogViewer. I also started the Gedi with -dbg SVN.
I tried something with the debugger and found the failure at the tmpnam() or at SVN_cmdline(). The used shell have no rights to create a file at the temp folder, so it can`t read the information from it. Its possible to write a hard path into the svnlib.ctl. Do you probably know which user will used to call system() ?
