Hello, recently found that DistSystemDisconnected doesn't fired when I stoped local Dist manager, but DistSystemConnected works fine.
In case of stopping dist manager on remote system all events works fine.
.NET API OaManager DistSystemDisconnected
- DKuchev@croc.ru
Re: .NET API OaManager DistSystemDisconnected
If the Dist manager in the local system is stopped a manager in the same system will get a system message DIST_SYS_MSG (DIST_SYSTEM_ALL_DISCONNECT) instead of DIST_SYS_MSG (DIST_SYSTEM_DISCONNECT) if only the connection to a specific system is lost.
