OPC Quality
Gyfee1
OPC Quality
Post by Gyfee1 »
Hello.
Have a OPC DA Server (WinCC OA 3.14 P028).
How to transfer quality "BAD", when "Value" is out of range, described in "pv_range". We've got "GOOD" in OPC DA Client.
alug
Re: OPC Quality
Post by alug »
Hallo,
the OPC DA server does not indicate the BAD quality if the value is out of range.
There are currently two possibilities to indicate this to the client.
1) you configure a Default value for the range violation. Than you see a GOOD:LOCAL_OVERRIDE quality on the client is the range is violated.
2) you set the _original.._exp_invalid attribute depending on the range violation attribute (_original.._out_prange) in the application,
because the _exp_invalid attribute is indicated and BAD status to the client.
best regards
