I'm trying to connect from WinCC OA to a PLCSIM Advanced Instance. The communication does not work.
I can ping the simulated PLC via the console and the connection to TIA Portal is fine.
The WinCC OA version: 3.16 SP5
S7-PLCSIM advanced: V2.0 SP1
My PC has the following Ethernet ports:
physical Ethernet port: 140.181.81.236
PLCSIM Virtual Ethernet adapter: 192.168.0.123
The log messages are as following:
WCCOAs7 (2), 2019.08.21 09:34:38.303, SYS, SEVERE, 13/s7, Common AGLink error (0xfff50005) for STRINGTEST_POLL(2/1), 13, 33028
WCCOAs7 (2), 2019.08.21 09:34:38.313, SYS, SEVERE, 13/s7, Common AGLink error (0xfff50005) for STRINGTEST_POLL(2/1), 21, 33028
WCCOAs7 (2), 2019.08.21 09:34:38.574, SYS, SEVERE, 7/s7, No active connection for STRINGTEST
WCCOAs7 (2), 2019.08.21 09:34:38.586, SYS, SEVERE, 7/s7, No active connection for STRINGTEST
WCCOAs7 (2), 2019.08.21 09:34:38.586, SYS, SEVERE, 13/s7, Common AGLink error (0xfff5001c) for STRINGTEST(1)
The front end diagnostic panel shows as DS IP the IP address of the physical adapter: 140.181.81.236
The error messages in the front end diagnostic panel are:
2019.08.21 09:07:43.484: Time synchronization STRINGTEST -> DS driver 2 Bad
2019.08.21 09:07:43.485: S7 driver TSPP/polling connection STRINGTEST -> DS driver 2 Bad
Do I have to specify the IP address for the DS somewhere? (shouldn't it be 192.168.0.123?)
Does the communication to PLCSIM Advanced work at all with the S7 driver (TSPP, Polling,...)?
Best regards
Christian Müller
Communication Problems to PLCSIM Advanced via S7 driver
- chrmue
- gschijndel
Re: Communication Problems to PLCSIM Advanced via S7 driver
For the S7 driver you have to specify the IP address of the CPU (not the PLCSIM virtual Ethernet adapter).
To prevent the 0xfff50005 errors you can use the config entry 'UseConnections = 1' or 'UseOneConnection = "Y"'.
But you could also use the S7Plus driver instead. It can access the PLCSIM without a PLCSIM virtual Ethernet adapter (also the non-advanced version).
Yes, polling PLCSIM advanced does work with the S7 driver.
BTW: What is DS?
BTW: What is DS?
