UDP communication via CTRL
Smiffy
Post by Smiffy »
I am wanting to write my own TFTP server in CTRL script. This should be entirely possible the TFTP protocol is quite simple. I want to do it in CTRL as that way I do not have to worry about future maintenance (windows updates) as I would if I wrote a windows api, and also the code can be maintained by staff without specialist C# knowledge.
1) I have successfully opened a UDP connection. However in doing so I have hard code the IP of the local host machine into the UDP open command. Ideally I would like to call a function to get the localhost machine reference for the UDP open command. I cannot just use "localhost" as the machine has several interfaces, not just the one.
2) The data I intend to read / write is a mixture of word and string data. When receiving into a string using udpRead() I get an error as some of the UDP packet data is not string data. So I tried to use a blob, but that doesn't work either as nothing is returned when I debug print the blob variable after the read. So how do I receive a mix data type UDP packet? It seems very inflexible if the udpRead can only read string data.
gschijndel
Re: UDP communication via CTRL
Post by gschijndel »
1) By using an empty string as host parameter it should listen to all interfaces.
2) I have read binary data with 'udpRead', so I am sure this is possible. Perhaps you could post your read part to identify the error.
Smiffy
Post by Smiffy »
Here is my code.
Rxbuf is the receive variable. It is a string, but I have tried a blob and that doesn't work either.
bool OpenPort()
    dyn_errClass Err;
    unsigned port = 69;
    TFTPPort = udpOpen("172.16.7.133", port);
    DebugN(TFTPPort);
    if (TFTPPort < 0)
        Err = getLastError();
        DebugN(Err);
        ClosePort();
        return FALSE;
    return TRUE;
void ClosePort()
   udpClose(TFTPPort);
main()
    int State = INIT;
    string RxBuf;
    dyn_string WriteHost;
    unsigned WritePort;
    dyn_errClass Err;
    for(;;)
        switch(State)
            case INIT:
            ClosePort();
            if (OpenPort())
                State = GETDATAPKT;
            break;
            case GETDATAPKT:
            if (udpRead(TFTPPort, RxBuf, WriteHost, WritePort, TIMEOUT) > 0)
                DebugN(WriteHost,WritePort,RXBuf);
            else
                DebugN(Err);
                if(dynlen(Err) > 0)
                    DebugN(Err);
            break;
        delay(0,1000);
Reason: Added code tags
gschijndel
Except that 'WriteHost' should be a string instead of dyn_string I do not see something wrong.
I have attached an example, which should help you get started with a TFTP server.
tftpServer.xml
(1.95 KiB) Downloaded 283 times
