I have connected to S7-1500 PLC after importing exported project from TIA. When I try to import data points such as attached example, there is no export when I select the project.
When I establish the connection I can see the exported project and I can drill down to data points.
I have set PUT/GET and disabled Optimized block access.
Graham
S7 +driver
- fmulder
Re: S7 +driver
We have connected some S7-1512PLC's (and other 15xx models) and have always used 'online browsing'. (we never use the TIA project in WinCC OA)
We use online browsing to manuallay make a couple of adresses. We then use scripting to generate the test
Maybe you can try online browsing to see where ypur problem is ?
share the func
Frenk Mulder
share the func
Frenk Mulder
- wahsbg
Re: S7 +driver
Same issue with online browsing. It says its connected but I still cant see data points, therefore I cant import.
- wahsbg
Re: S7 +driver
From datapoints I was able to drill down online.
I still need to loo at an import of a project file for bulk engineering. If anyone can advise.
Thanks,
Graham
Thanks,
Graham
- gschijndel
Re: S7 +driver
The TIA importer uses some fixed values, which are most likely not optimal for your project(s).
Therefore you should consider other options to configure your addresses.
