I would like to connect my control script with my C# Manager while my table is initializing.
I use WinCC OA 3.16.
Is this possible ? I just find the connection with data-points over an subscription.
I look forward to hear from you.
Regards NOertel
How to Call C# Function from CTRL Skript
Re: How to Call C# Function from CTRL Skript
You cannot "connect" to another manager from your CTRL script in standard configuration.
This would only be possible if your C# manager is opening an additional server port where some (external) process can connect to.
Why aren't you transferring data from the C# manager to the CTRL script via DP elements?
- NOertel
I thought I could use C# with an ORM Framework so I'm able to load queries without datapoints into the table.
But, now I'm convinced that CTRL an DP could be also an good alternative. Thanks for the good Basic Workshop
Best Regards,
NOertel
Best Regards,
NOertel
