Profisafe Communication Between 400-H PLC and WinCC OA 3.16
Kalai123
Post by Kalai123 »
Anyone can give an example program/ procedure to get Profisafe communication between 400-H PLC and WinCC OA 3.16?.
Thanks in advance!
gschijndel
Re: Profisafe Communication Between 400-H PLC and WinCC OA 3.16
Post by gschijndel »
I do not have an example. But if there is something unclear from the documentation or you have a specific question, we might be able to help you.
Kalai123
Post by Kalai123 »
Thanks for your reply.
Though I followed the steps which are mentioned in the WinCC OA Help file for Profisafe communication in TIA, I have faced some errors while configuring.
Please find the attached file, which has the comparison of WinCC OA Help file and Real Scenario in TIA.
Kindly go through it and let me know the solution.
Thanks in advance!
Comparison of TIA configuration help in WinCC OA and Real Scenario.xlsx
(1.6 MiB) Downloaded 322 times
kumar.samarth@tcs.com
Profisafe Communication Between 4175-H PLC and WinCC OA 3.16
Post by kumar.samarth@tcs.com »
We have a requirement to establish and test communication of S7 417-5H CPU (redundant configuration) with WinCC-OA V3.16 over profisafe comms.
If there is any implemented or tested reference program or manual for configuring safety communication between S7 417-5H and WinCC-OA available then kindly share.
Also, I have already tried to configure communication following the steps which are mentioned in the WinCC OA Help file for Profisafe communication in TIA and observed some errors. Please find the attached file, which has the comparison of WinCC-OA Help file and Real Scenario in TIA.
If any solution is available kindly share it on proirity.
Thanks in advance
(1.6 MiB) Downloaded 288 times
