Create a class in CTRL with an attribute which type is another class
ange.ogawin
Post by ange.ogawin »
I want to create a class with an attribute which has as type another class.
For example,in libFile.ctl:
class A
public int att;
public A(int att){ this.att=att;}
class B
public A a;// line X
public B(A a){this.a=a;}
in initialize event of graphic object:
#uses "libFile"
main()
A a=new A(1);
B b=new (a);//here the error "Argument missing in function" and referencing the line X.
Any idea to solve this?
Thank;
ozangor
Re: Create a class in CTRL with an attribute which type is another class
Post by ozangor »
Not tested, but first thing i see is,
when creating stack objects don't use "new" keyword. Rather use:
A a = A(1);
the problem is in line
B b=new (a);
it should be:
B b = B(a);
Hope it works.
dvribeira
Post by dvribeira »
Hi
Assuming you want to store a copy of a in b, and not a reference, then the following code would work:
class A {
    public int att;
    public A(int att = 0){ this.att=att;}
class B {
    public A a;
main() {
    A a = A(1);
    B b = B(a);
    DebugN(a, b);
Output:
WCCOActrl2:[instance 000002808588FF70 of class A
WCCOActrl2:"att" : 1][instance 000002808588FA70 of class B
WCCOActrl2:"a" : instance 000002808588FAB0 of class A
WCCOActrl2:	"att" : 1]
As you can see the first instance of A (the object named a) is different than the one stored within b, so changes to one won't affect the other. If you wanted to store the same, then have a look at shared pointers.
The two problems with your code would be then:
a) the usage of the "new" keyword, which should be used to fetch a shared pointer instead as pointed out by @ozangor
b) you should provide a default argument to A's constructor. WinCC OA will try to construct the B property of type A before its own constructor gets executed so if you don' provide a default argument, it will fail. If you would have used a shared pointer, then it would have been initialized as nullptr before construction.
Alternatively, to solve b), you could also initialize the property on declaration and avoid putting a default argumet in A's constructor:
class A {
    public int att;
class B {
    public A a = A(0);
main() {
    A a = A(1);
    B b = B(a);
    DebugN(a, b);
I hope it helps!
Daniel
EDIT: for what I see: a) is not a problem any more I guess since the new features of P013... so you can now use the new keyword both for objects and shared pointers. For the latter, that's the only allowed option.
