Hello.
Can you help. How disable logging INFO messages, when use option "messageCompression". (v. 3.15 P020)
WCCILdist (1), *, PARAM,INFO, 0, , Setting message compression for (SYS: * Dist -num 1 CONN: 1) to zlib-bzip2
Message Compression
Re: Message Compression
If the message compression is activated you get the information that it is active when a connection is established.
There is no possibility to suppress the log message.
Why do you want to disable the log message?
- Gyfee1
There are too many messages in Logviewer, if connected more then one system (for ex. 14-15 redandunt systems). This config is spaming every minute.
The information is written only once when the connection is established.
If you get the log messages several times you possibly have connection problems between the distributed systems.
Please check the log files and your system to see if the connections are stable or not.
