I have a project that has two identical structures (Real, Simulation)
Realpart;
\Panels\P2018\BaseWindow.pnl
using
TAB
EMBEDDED_MODULE "EMBEEDDEB_SIDEMENU)
any more
Simulationpart:
\Panels\P2018SIM\BaseWindow.pnl
using
TAB
any more
In the EMBEEDDEB_SIDEMENU I'm using TREE_WIDGETS
When I directly invoke the base panels individually, the tab and the embeedded_module work
When I change from the Realpart to the Simulationpart with RootPanelOn all works fine with the exception of the TREE_WIDGETS, the Windows from the TREE WIDGETs are not set up and remain empty (appendItemNC, ....).
I first sart the simulation part and then change with RootPanelOn to the real part the TRRE_WIDGETS do not work in real
Whats wrong ?
RootPanelOn
Re: RootPanelOn
Possibly for the analysis we would need the panels.
Only with the description we cannot see what the panels are doing and which scripts are started.
For further investigation please get in contact with your common WinCC OA support.
- marcel.gay@wimag.ch
Re: RootPanelOn
The project includes compressed 100MB
Could we connect by Teamviewer or eg ?
Or can I send you only parts of the project (like ..pnl, pictures. ...)
Re: RootPanelOn
If you want to get assistance from the official WinCC OA support please use the Siemens Industry Portal to submit a service request.
