Scaling issues in windows 10 on IPC227E
1 post • Page 1 of 1
MattPaulissen
Post by MattPaulissen »
For some reason the scaling on my embedded modules doesn't work once I move my project to a windows 10 IPC. On my dev machine the responsive templates were working perfectly, and I could resize the main window to whatever size I wanted without creating scroll bars on my main embedded module. On the IPC it doesn't try to scale it at all though, and I end up seeing about 1/4 of the main screen and the embedded module has scroll bars in it.
I even tried modifying the template and placing this in each module:
setScaleStyle(SCALE_FIT_TO_MODULE, this.ModuleName());
Is there some windows setting I need to change? Or maybe some UI switch I don't know about? My UI has the following switches:
-p vision/startup.pnl -iconBar -menuBar
