Settings for the Modbus driver
atrejman
Post by atrejman »
Applying parameter "aliveTimeoutMsg 3 816" in section [mod] in "config file" cause following problem.
The edited config file has invalid entries. Please check your changes! Would you like to edit the file again?
WinCC 3.16 P011
adaneau
Re: Settings for the Modbus driver
Post by adaneau »
As any config entry, you must use = sign :)
So use aliveTimeoutMsg = 3 816 instead of "aliveTimeoutMsg 3 816"
Alex
atrejman
Post by atrejman »
Thanks for your answer. it's works :)
And by the way, you can tell me,
may I use different settings for each modbus drivers?
E.G.
[mod1]
[mod2]
aliveTimeoutMsg = 3 100
till now common settings were enough for my config
[mod]
adaneau
Post by adaneau »
Yes you can use different settings for different instances of the driver, I am myself using it for endianity.
Correct syntax is :
[mod_xx] where xx is the driver number. So for you [mod_1] and [mod_2]
BTW this is valid as well for any manager ;).
Br
Alexandre Daneau
