Hello Everyone,
I'm using Windows 7 (As a Workstation) as desktop UI.
In Trend component, i'm trying to drag and drop data points from para to trend component, unfortunately; it always causes the application and desktop UI to collapse !, While using the same over windows 10 and everything seems working fine.
Are there some sort of special installations for Windows 7 to fulfill the requirements for such cases in WinCC OA ?. noting that we installed the same .Net framework used in windows 10 over 7 and the issue remains.
Any recommendations ?
Regards
Maher
Windows 7 Trend Client Crash over Desktop UI
- maherhodali
Re: Windows 7 Trend Client Crash over Desktop UI
Can you please add the information which WinCC OA version and patch you are using.
Maybe the version is different on your machines and therefore it only occurs on Windows 7.
- maherhodali
Im using WinCC OA 3.16 Patch 001 for both.
Regards
Maher
Regards
Maher
Please do an upgrade to the newest patch P012 for WinCC OA 3.16 and check afterwards if the problem still occurs.
- saleemjammal
Dear ,
we have upgraded both wincc oa and the winccoa disctop ui to pach 12 ,
but still we have the same issue !
is there any other solution to fix this issue on windows 7 ?
I have tested it on Windows 7.
If I do a simple drop of a dp element to the trend and do a connectDirectly for the dp element no problem occurs.
Maybe you can provide a simple test panel where the problem occurs.
