graph's with very big numbers
genkihenkie
Post by genkihenkie »
So we are getting these huge numbers, for the data throughput.. and for the GUI text we changed them to readable numbers.
Which work nicely and makes the values readable and usable for normal people (in this case 964b)
txt_eth0_rx.text = WSRTCommon_getHumanSize(eth0_rx*8/60, FALSE, TRUE);
- Where getHumanSize is this part:
string WSRTCommon_getHumanSize(float nr, bool MiB=TRUE, bool BIT=FALSE)
  int value = 1000;
  dyn_string suffixes;
  if (!MiB)
    if (BIT)
      suffixes = makeDynString("b", "Kb", "Mb", "Gb", "Tb", "Pb", "Eb");
    else
      suffixes = makeDynString("B", "KB", "MB", "GB", "TB", "PB", "EB");
  else
    value = 1024;
    suffixes= makeDynString("b", "Kib", "Mib", "Gib", "Tib", "bib", "Eib");
    if (! BIT)
      suffixes= makeDynString("B", "KiB", "MiB", "GiB", "TiB", "biB", "EiB");
  // converts disk/file sizes to human readable form
  int idx = 1;
  while (nr >= value && idx <= dynlen(suffixes))
    nr /= value;
    idx += 1;
  string val,out;
  sprintf(val, "%.2f", nr);
  if (nr > 0)
    out = strrtrim(val,"0.") + " " + suffixes[idx];
  else
    out = val + " " + suffixes[idx];
  return out;
// base :  give base to translate to  base 2 means 01-99)  base 3 means 001-999
string WSRTCommon_addPendingZeros(uint number, int base)
  if (base != 2 && base != 3)
    DebugN(__FILE__ , __FUNCTION__, "Error: base not implemented, should be 2 or 3 ", base);
    return "Error";
  if (base == 2 && number > 99)
    DebugN(__FILE__ , __FUNCTION__, "Error: number for base 2 should be < 99", number);
    return "Error";
  if (base == 3 && number > 999)
    DebugN(__FILE__ , __FUNCTION__, "Error: number for base 3 should be < 999", number);
    return "Error";
  string retval = "";
  string extra;
  if ((number < 10 && base == 2) ||  (number >= 10 && number < 100 && base == 3 ) )
    extra = "0";
  else if (number < 10 && base == 3 )
    extra = "00";
  retval = extra + number;
  return retval;
But how do I do it in a trend graph? I got a request to show the last few hours of the throughput in a graph on top of the page.
I don't have any options there when I double click the graph. I can just connect to a datapoint and show that..
Result right now is that I am displaying 14 digit numbers (in this case 15652865389530.00) in a graph, and that makes the scale on the side huge and unusable .
Reason: Placed code tags
gschijndel
Re: graph's with very big numbers
Post by gschijndel »
The trend has a feature to map a text to a value (curveValuesTexts), but it only changes the shown value in the legend and ruler window. So it does not help with the scale(s).
It is also possible to fill the trend with own values, so it is possible to do self the connect, fill the trend with readable values and provide some suffix indication outside the trend.
