Starting GEDI with different language
NikolayLevchenko
Post by NikolayLevchenko »
I have a multi-language project and I need to provide customer with an Engineering Station with ability to use it in any of the project languages.
The server and client projects have smth like this in config:
# Project languages
langs = "de_DE.utf8"
langs = "en_US.utf8"
langs = "ru_RU.utf8"
# Default project language
# for menus, etc.
lang = "en_US.utf8"
The Engineering Client is started via a batch file, smth like:
START C:\Siemens\Automation\WinCC_OA\3.15\bin\WCCOAui.exe -proj EngineeringUI_xxx -m gedi -user username
Problem: GEDI always starts in English. I can switch the language for panels inside the GEDI but not the GEDI interface itself (menus, etc.).
Question:
Is there any way to define interface language at startup? I can't seem to find any WCCOAui.exe options to do it. The most obvious way is to create 3 Engineering Client projects with different lang in their respective config files but this seems like an overkill.
Is there a simpler solution to this?
buec
Re: Starting GEDI with different language
Post by buec »
Add -lang de_DE.utf8 to your batch file and the GEDI will start in German.
BR Christoph
