Recovering old archive values
jonred
Post by jonred »
a client is storing some data in archive_1. LAter, we added more data to that archive (same datapoints type, usign ascii manager). because a config mistake, the data stored is from about 5 months now, when previously it was for about 2 years. they noticed when trying to report the last current year data. i changed the stored datapoints in archive configuration, so the data should be strored correctly now, but i need to recover the old data.
I made a copy of the project and tested the method in my test enviroment.
I tried to delete the archives and restore archives from online backup using th option from database configuration -> Activity, but the archives don't appear and data can't be retrieved via repottings -> sql query. The files are actually copied from de backup directory to the project directory, but WinCC OA can't "see" them.
Now, i only have last file data. (i am using a copy of the project in my lab)
¿What is the reason for this?
Thank you very much
Re: Recovering old archive values
Possibly the old files are already marked as "deleted" and therefore you cannot access the files.
You can try to
-- configure a backup directory for the value archive
-- copy the old archive files to this directory
-- use the archive configuration panels to restore the files
jonred
Post by jonred »
Thank you, I tried that in my lab and i could recover the old data.
In a redundant system, i suposse i have to delete the online files to recover from both servers, and then recover using the activity panel in the active host, true?
Thank you very much
I do not understand why you want to delete first the files which are online and then import them again.
If they are already online there is no need to delete them.
The active/passive state of the redundancy has no effect on the server you are using for importing old archive files.
