Disconnect distributed system
Victor.Ermakov
Post by Victor.Ermakov »
Hello.
I have a problem with my distributed system.
My project consists of 1 server system (ID;1 ServerWeb:170.1.1.1), 2 remote systems (ID:101, ID:108) and 4 workstations (with ui manager).
When I open the user interface on a specific workstation, the connection to one of the remote system (ID:101) is broken (after 1 hour and more).
After that the message appears in the logs:
On a remote system:
WCCILdist (1), 2019.07.05 04:23:13.541, SYS, INFO, 4, Connected to (SYS: 1 Dist -num 1 CONN: 1) @ ServerWeb (170.1.1.1)
WCCILdist (1), 2019.07.05 04:23:13.572, PARAM,INFO, 1/dist, Requested identification from MAN: (SYS: 1 Dist -num 1 CONN: 1(R))
WCCOActrl (3), 2019.07.05 04:23:13.946, SYS, INFO, 162, Got connection to system 1
WCCILdata (0), 2019.07.05 04:23:13.946, SYS, INFO, 162, Got connection to system 1
WCCOActrl (1), 2019.07.05 04:23:13.946, SYS, INFO, 162, Got connection to system 1
WCCOActrl (4), 2019.07.05 04:23:13.946, SYS, INFO, 162, Got connection to system 1
WCCILdist (1), 2019.07.05 04:23:27.686, SYS, SEVERE, 39, Connection lost, Send buffer limit exceeded, closing connection to (SYS: 1 Dist -num 1 CONN: 1) @ ServerWeb, [PeerItcIOHandler::sendCall]
WCCILdata (0), 2019.07.05 04:23:27.706, SYS, SEVERE, 160, Lost connection to system 1
WCCOActrl (3), 2019.07.05 04:23:27.706, SYS, SEVERE, 160, Lost connection to system 1
WCCOActrl (1), 2019.07.05 04:23:27.706, SYS, SEVERE, 160, Lost connection to system 1
WCCOActrl (4), 2019.07.05 04:23:27.707, SYS, SEVERE, 160, Lost connection to system 1
On a server system:
WCCILproxy (1), 2019.07.05 04:21:43.593, SYS, WARNING, 5, Connection not possible, Closing connection to peer: ::ffff:170.1.1.101:61744. Reason: [proxy] acceptTimeout = 100 expired before configuration arrived.
WCCILdist (1), 2019.07.05 04:23:13.659, SYS, INFO, 4, Connected to (SYS: 101 Dist -num 1 CONN: 1) @ ServerWeb (::1)
WCCOActrl (3), 2019.07.05 04:23:14.051, SYS, INFO, 162, Got connection to system 101
WCCOActrl (1), 2019.07.05 04:23:14.051, SYS, INFO, 162, Got connection to system 101
WCCILdata (0), 2019.07.05 04:23:14.051, SYS, INFO, 162, Got connection to system 101
WCCOActrl (4), 2019.07.05 04:23:14.051, SYS, INFO, 162, Got connection to system 101
WCCOAui (3), 2019.07.05 04:23:14.053, SYS, INFO, 162, Got connection to system 101
WCCOAui (4), 2019.07.05 04:23:14.052, SYS, INFO, 162, Got connection to system 101
wccoaui (5), 2019.07.05 04:23:14.054, SYS, INFO, 162, Got connection to system 101
WCCILdist (1), 2019.07.05 04:23:27.798, SYS, WARNING, 39, Connection lost, MAN: (SYS: 101 Dist -num 1 CONN: 1), Connection reset by peer (10054)
WCCILdata (0), 2019.07.05 04:23:27.814, SYS, SEVERE, 160, Lost connection to system 101
WCCOActrl (3), 2019.07.05 04:23:27.815, SYS, SEVERE, 160, Lost connection to system 101
WCCOActrl (4), 2019.07.05 04:23:27.815, SYS, SEVERE, 160, Lost connection to system 101
WCCOAopcsrv (1), 2019.07.05 04:23:27.817, SYS, SEVERE, 160, Lost connection to system 101
WCCOAui (3), 2019.07.05 04:23:27.818, SYS, SEVERE, 160, Lost connection to system 101
wccoaui (5), 2019.07.05 04:23:27.818, SYS, SEVERE, 160, Lost connection to system 101
I do not understand why this is happening. Please help understand.
Last edited by Victor.Ermakov on Fri Jul 05, 2019 9:34 am, edited 1 time in total.
Re: Disconnect distributed system
In the part of the log message there is a Russian text which I cannot read.
Can you please tell us which information is written there.
Victor.Ermakov
leoknipp wrote: ↑ Fri Jul 05, 2019 9:15 am In the part of the log message there is a Russian text which I cannot read.
Russian text translated "Requested identification from"
all logs without russian text
WCCILdist (1), 2019.07.05 04:23:13.572, PARAM,INFO, 1/dist, Requested identification fromт MAN: (SYS: 1 Dist -num 1 CONN: 1(R))
gschijndel
Post by gschijndel »
I would start to look at the first highest priority error:
Apparently this remote system sends too much data to the server system. You should check why this remote system sends so much data.
