How to set Hover Back/ForeColor by CTRLScript?
uxout
Post by uxout »
is there a way to modify the configuration of a graphic object (eg. a button) by using a CTRLScript function?
Regards
uxout
Re: How to set Hover Back/ForeColor by CTRLScript?
Post by uxout »
I guess not, maybe a future update will add this feature? :D
adaneau
Post by adaneau »
You are right, I found the property in the xml but it cannot be accessed via ctl code ...
<prop name="HoverBackCol">yellow</prop>
However I see a quick workaround using the mouseover script :)
You can even embed it into a OOP with your own custom hover property to make it usable everywhere.
Alexandre
