Run script .ctl from an graphical object event
ange.ogawin
Post by ange.ogawin »
Is it possible to run a script located in script folder of WinCC OA project from an event of a graphical object, like "clicked" for a push button?
How?
Thank you.
Re: Run script .ctl from an graphical object event
Yes it is possible to start a script which is located in the scripts folder with a system() command starting a WinCC OA CTRL Manager.
Another solution is to load the script into a string variable and call the function execScript() with the string variable as parameter.
Why do you want to start a script instead of defining the same code as function in a library and call the function?
Should the script run all the time or is it a script which runs and then stops when the execution is finished?
