Time Sync - Client/Server
slamkwon
Post by slamkwon »
When the client (UI) and the HMI server are not time synchronized, VISION displays an error and turns off.
1. How much of a time difference will result in an error?
2. How long (or what is the trigger) before VISION realizes in the time difference and turns off?
Re: Time Sync - Client/Server
per default 30 seconds. You can change the value, but it can cause problems. It is better to syncronize time.
gschijndel
Post by gschijndel »
kilianvp wrote: ↑ Fri Jun 21, 2019 1:17 pm per default 30 seconds. You can change the value, but it can cause problems. It is better to synchronize time.
Since 3.11(+SP1) this is no longer the case, also with a bigger time difference the UI will connect (but a warning is written in the log).
Details can be found in the documentation: WinCC OA UI -> Remote user interface -> Synchronization Client-Server
gschijndel wrote: ↑ Fri Jun 21, 2019 5:16 pm
Details can be found in the documentation: WinCC OA UI -> Remote user interface -> Synchronaization Client-Server
but a dpSet would be invalid???
i always had to adjust the config entry valueChangeTimeDiff
gschijndel
kilianvp wrote: ↑ Fri Jun 21, 2019 5:40 pmbut a dpSet would be invalid???
No, the UI time is ignored and the event manager will use its own time for the value.
