Create new project without UI
8 posts • Page 1 of 1
uxout
Post by uxout »
Is it possible to create a new project without going into the Project Administrator ? (ie : CTRL Script ? Copy folder of a new project + register? Other?)
My goal is to create a new project with some default config.
I tried to use the function paCreateProjExtend() from pa.ctl but it isn't working.
Any idea/sugestion would be appreciated.
Thanks !
Re: Create new project without UI
If you want to register an already existing project on a machine you can
-- copy the project to the machine
-- register the project by calling WCCILpmon -config <path to the config file> -autoreg -noAutoStart
-- stop WCCILpmon
Now the project should be registered.
uxout
Post by uxout »
I want to generate a new standard project from command line. Is it possible?
Why do you want to create a new project from command line?
What is the use case for creating a project "manually"?
uxout
Post by uxout »
It is needed for continuous integration purpose.
I just wanted to know if it is possible or should I just copy a sample project?
There is no command line call available to create a new project.
Creating the project is done with a CTRL command which calls then C++ functions in WinCC OA.
gschijndel
Post by gschijndel »
You could also create a script, which creates a new project, and call this script from the command line (without event connection).
But copying a sample project would be easier. To prevent somebody from expanding the sample database and to be sure that the testing starts with an empty database, you could create a new database with 'WCCOAtoolCreateDb'.
uxout
Post by uxout »
Copying a sample project will be the way to go then !
Thanks for the informations.
