Maximum Screen Resolution allowed in WinCC OA
paramesh1985
Post by paramesh1985 »
In WInCC OA standard template is supporting the screen resolution upto 1920 x1200.
It could be possible to make the template with more than that resolution like 3840 x 2160 or 4096 x 2160 for 4K screen display.
Otherwise it is possible to call the specific panel with that resolution.
Is there any restriction in WinCC OA .
Thanks .
R.Parameshwaran.
Re: Maximum Screen Resolution allowed in WinCC OA
If you want to you can create templates with a size bigger than 1920 x1200.
When a panel has a defined size and there is no layout defined the panel does not expand to the size of the module if the module is bigger than the panel.
