I have problem on 3.15 version.
I created newEwo and compile by MSVC15 x64 compiler.
Build success.
Where I put on widget on panel, I see error. And where I started panel with widget, than I get error:
WCCOAui (2), 2019.06.11 12:41:26.795, SYS, WARNING, 133, Could not load shared library C:\WinCC_OA_Proj\ARM\bin\widgets/windows-64/langWidget.ewo, The specified procedure could not be found.
WCCOAui (2), 2019.06.11 12:41:26.797, SYS, WARNING, 36/uim, The EWO "C:\WinCC_OA_Proj\ARM\bin\widgets/windows-64/langWidget.ewo" is version "1", but we can only load version "4"
WCCOAui2:VarAttrElem "pixmap" isAttribute(): type not implemented:QVARIANT_VAR
build log here:
12:40:17: Running steps for project langWidget...
12:40:17: Starting: "C:\Qt\Tools\QtCreator\bin\jom.exe" clean
C:\Qt\Tools\QtCreator\bin\jom.exe -f Makefile.Release clean
del release\moc_predefs.h
del release\moc_langWidget.cpp
del release\langWidget.obj release\moc_langWidget.obj
del release\langWidget.exp
C:\Qt\Tools\QtCreator\bin\jom.exe -f Makefile.Debug clean
del debug\moc_predefs.h
del debug\moc_langWidget.cpp
del debug\langWidget.obj debug\moc_langWidget.obj
del debug\langWidget.exp debug\langWidget.vc.pdb debug\langWidget.ilk debug\langWidget.idb
Could Not Find C:\Siemens\Automation\WinCC_OA\3.15\api\langWidget\debug\moc_predefs.h
Could Not Find C:\Siemens\Automation\WinCC_OA\3.15\api\langWidget\debug\moc_langWidget.cpp
Could Not Find C:\Siemens\Automation\WinCC_OA\3.15\api\langWidget\debug\langWidget.obj
Could Not Find C:\Siemens\Automation\WinCC_OA\3.15\api\langWidget\debug\langWidget.exp
del langWidget.exp
Could Not Find C:\Siemens\Automation\WinCC_OA\3.15\api\langWidget\langWidget.exp
12:40:17: The process "C:\Qt\Tools\QtCreator\bin\jom.exe" exited normally.
12:40:17: Configuration unchanged, skipping qmake step.
cl -c -nologo -Zc:wchar_t -FS -Zc:rvalueCast -Zc:inline -Zc:strictStrings -Zc:throwingNew -Zc:referenceBinding -O2 -MD -W3 -w34100 -w34189 -w44996 -w44456 -w44457 -w44458 -wd4577 -wd4467 -EHsc -DUNICODE -D_UNICODE -DWIN32 -DWIN64 -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DNDEBUG -D_WINDLL -I. -Ic:\Siemens\Automation\WinCC_OA\3.15\api\include\EWO -IC:\Qt592\5.9.2\msvc2015_64\include -IC:\Qt592\5.9.2\msvc2015_64\include\QtWidgets -IC:\Qt592\5.9.2\msvc2015_64\include\QtGui -IC:\Qt592\5.9.2\msvc2015_64\include\QtANGLE -IC:\Qt592\5.9.2\msvc2015_64\include\QtCore -Irelease -IC:\Qt592\5.9.2\msvc2015_64\mkspecs\win32-msvc -Forelease\ @C:\Users\Evil\AppData\Local\Temp\langWidget.obj.1928.16.jom
langWidget.cxx
cl -BxC:\Qt592\5.9.2\msvc2015_64\bin\qmake.exe -nologo -Zc:wchar_t -FS -Zc:rvalueCast -Zc:inline -Zc:strictStrings -Zc:throwingNew -Zc:referenceBinding -O2 -MD -E C:\Qt592\5.9.2\msvc2015_64\mkspecs\features\data\dummy.cpp 2>NUL >release\moc_predefs.h
C:\Qt592\5.9.2\msvc2015_64\bin\moc.exe -DUNICODE -D_UNICODE -DWIN32 -DWIN64 -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DNDEBUG -D_WINDLL --compiler-flavor=msvc --include release/moc_predefs.h -IC:/Qt592/5.9.2/msvc2015_64/mkspecs/win32-msvc -IC:/Siemens/Automation/WinCC_OA/3.15/api/langWidget -Ic:/Siemens/Automation/WinCC_OA/3.15/api/include/EWO -IC:/Qt592/5.9.2/msvc2015_64/include -IC:/Qt592/5.9.2/msvc2015_64/include/QtWidgets -IC:/Qt592/5.9.2/msvc2015_64/include/QtGui -IC:/Qt592/5.9.2/msvc2015_64/include/QtANGLE -IC:/Qt592/5.9.2/msvc2015_64/include/QtCore -I"C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.16.27023\ATLMFC\include" -I"C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.16.27023\include" -I"C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\include\um" -I"C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\ucrt" -I"C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\shared" -I"C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\um" -I"C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\winrt" -I"C:\Program Files (x86)\Windows Kits\10\include\10.0.17763.0\cppwinrt" langWidget.hxx -o release\moc_langWidget.cpp
cl -c -nologo -Zc:wchar_t -FS -Zc:rvalueCast -Zc:inline -Zc:strictStrings -Zc:throwingNew -Zc:referenceBinding -O2 -MD -W3 -w34100 -w34189 -w44996 -w44456 -w44457 -w44458 -wd4577 -wd4467 -EHsc -DUNICODE -D_UNICODE -DWIN32 -DWIN64 -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DNDEBUG -D_WINDLL -I. -Ic:\Siemens\Automation\WinCC_OA\3.15\api\include\EWO -IC:\Qt592\5.9.2\msvc2015_64\include -IC:\Qt592\5.9.2\msvc2015_64\include\QtWidgets -IC:\Qt592\5.9.2\msvc2015_64\include\QtGui -IC:\Qt592\5.9.2\msvc2015_64\include\QtANGLE -IC:\Qt592\5.9.2\msvc2015_64\include\QtCore -Irelease -IC:\Qt592\5.9.2\msvc2015_64\mkspecs\win32-msvc -Forelease\ @C:\Users\Evil\AppData\Local\Temp\moc_langWidget.obj.1928.484.jom
moc_langWidget.cpp
link /NOLOGO /DYNAMICBASE /NXCOMPAT /INCREMENTAL:NO /DLL /SUBSYSTEM:WINDOWS /MANIFEST:embed /OUT:release\langWidget.dll @C:\Users\Evil\AppData\Local\Temp\langWidget.dll.1928.1625.jom
Creating library release\langWidget.lib and object release\langWidget.exp
12:40:19: The process "C:\Qt\Tools\QtCreator\bin\jom.exe" exited normally.
12:40:19: Elapsed time: 00:02.
