Connect with Desktop UI failed
marcel.gay@wimag.ch
Post by marcel.gay@wimag.ch »
I have tried the connection of two different PC's and get the same problem
The image should contain all information about the current state
Re: Connect with Desktop UI failed
For the analysis we would need more information, e.g. the config file for the server to see which settings are made at the server.
According to the screenshots you are using a normal UI and not a Desktop-UI.
The project administration for a Desktop-UI looks different and does not a Process Monitor.
marcel.gay@wimag.ch
Yes, i'm using normal Desktop UI
marcel.gay@wimag.ch
I made the correction hpptServer} -> httpServer] and I erased the project and made new.
The Problem is still present
mplatz
Post by mplatz »
Dear Marcel,
It seems this is related to your second post:
viewtopic.php?f=15&t=10627
(same project)
For detailed analysis please get in contact with your common WinCC OA support.
kr,
Platzer Matthias
Possibly the firewalls in your system are blocking the TCP messages between the server and client.
To get more information you can activate debug flags on server and client side, e.g. -dbg dispatch for the UI manager and the Proxy-Manager on the server.
Please check if the Proxy Manager is started at the server, according to the config file the SSL communication is used.
