Can we add an ActiveX object to WinCC OA library?
Thanks,
jocin
ActiveX
Re: ActiveX
In WinCC OA you can insert an ActiveX component which is installed at the operating system into a panel. In GEDI you will find an object to add an ActiveX element. After adding the object to the panel you have to choose the ActiveX element you want to use.
Please take into account that only 64bit ActiveX elements can be used.
