Ewo Widget process running UI
jeissonsierrac
Post by jeissonsierrac »
Hello everyone
i´m developing a Widget for watch some cameras with a software provider, I´m recently doing some tests to check performance and resources, In one of my testI realized that an executable UI process was running even when I closed the UI,I implemented a destroy method for different processes that would close when the graphical interface was closed, I verify and the processes are closed correctly but it is still running the executable UI process, I would like to know if this is normal in terms of WinCC OA processing or should I implement some class so that it closes completely
thanks
gschijndel
Re: Ewo Widget process running UI
Post by gschijndel »
Did you check the command line arguments of the still running UI? Perhaps this UI was the console.
