I'm sure it's not a licensing issue because I deleted all the project tags.
The problem is that from error only if specific variables are active, so for example if the first 5 are active not by error, if I turn them off and only 6 is active by error.
I can't deal with it.
I created the driver connections again, the managers, restarted the project and reinstalled wincc.
Use 3.16 P006 (waiting for P010 I / O field bug resolution) discussed here: viewtopic.php?f=15&t=10580
This error is reapeted for each DPE for each property:
WCCOAui (2), 2019.05.31 09:17:54.178, SYS, WARNING, 0, , Error setting config (477), System1:3.STATUS.SGN_STATUS:_address.._subindex, 0
WCCOAui (2), 2019.05.31 09:17:54.187, CTRL, WARNING, 5/ctrl, Location of the following log entry:
Module: Para_1
Panel: C:\Siemens\Automation\WinCC_OA\3.16\panels\para.pnl [Datapoint parameterization]
Object: 10 named: "activeX" of type: DP_TREE
Script: OnRButtonClk
Library: C:\Siemens\Automation\WinCC_OA\3.16\scripts\libs\mp.ctl
Line: 1296
