How can I create a Side-Box / Side menu?
I mean you drive for example with the mouse on the right edge and a menu moves into the image area
I'm using WinCC OA 3.16
Sidebox / Side Bar Menus
Re: Sidebox / Side Bar Menus
I have seen that you have also submitted a service request with the same question. You will get an answer from the WinCC OA support team.
P.S.: Please do not ask the same questions in different tools (Siemens Industry Support and WinCC OA Portal).
If you want to share the information with the WinCC OA community you can use the WinCC OA Portal. Please take into account that the WinCC OA Portal shall not be used for WinCC OS support requests.
- marcel.gay@wimag.ch
I am not sure if the comment "Important: Common Rules for the WinCC OA Portal" was for this post
I find the Siemens Industry Support very confusing
Is it ok if I post here in the future ?
The "Common Rules" posting we have added to the WinCC Portal have been added end of April. It is a sticky post and therefore it is always displayed on top.
You can use the WinCC OA Portal for questions related to WinCC OA but you have to keep in mind the information given in the "Common Rules".
The advantage of using the Siemens Industry Support is that you have guaranteed response times (based on your service contract) and that every request will be answered by the WinCC OA Support Team.
For a posting made in the WinCC OA Portal it can also happen that it takes days or longer until someone in the community is writing an answer.
Sometimes it is also necessary to share project specific information to be able to answer your questions.
In the WinCC OA Portal you will share the information with the whole community and adding a lot of data in the WinCC OA Portal is not the intended use case for a portal.
