Trend widget - jump timespan with click on scrollbar
funkey
Post by funkey »
I have a problem with trend widget. I|m quite sure on earlier versions of WinCC OA this worked the right way. I use V3.15 an when I click on the scrollbar in trend widget the time jumps to time units back instead of one. I attached a picture to make the issue clearer. If I click back in time I always see for example every second hour instead of every hour.
Is this a bug or a setting?
Christoph
Re: Trend widget - jump timespan with click on scrollbar
We already know the problem and our development department is working on it.
At the moment it is not defined when the problem will be solved.
funkey
Post by funkey »
Hello!
Any news about this problem?
Christoph
The problem was solved with P020 for WinCC OA 3.15.
funkey
Post by funkey »
Thanks for information, great news! Thanks!
