datapoint attributes to an A&E Row
RKoczan
Post by RKoczan »
Adding addition datapoint alert attributes as a column to an A&E Row
I'm trying to add an dp attribute as a column to an A&E Row.
The attribute is _alert_hdl.._add_value_1
It seems straight forward to add the column by following the steps, selecting Edit Row tab then the Alertrow tab and adding a column, selecting the attribute from the list and applying.
However its not displayed in runtime. Other changes I make to the existing columns do change but the new column isn't displayed.
Does anyone know why? what to do?
Re: datapoint attributes to an A&E Row
Maybe you have not added the new column to the list of visible columns in the settings for the AERow and the configuration you are using for the AERow.
Please check the settings and add the column.
Somtimes it helps if you click the "Delete RT DPs" button and restart the UI.
Are you sure you're really changing the settings for A&E Row?
