Alert Config creation is giving error via script
paramesh1985
Post by paramesh1985 »
Tried to create the Non binary alert handling config for
the binary DPE. Config has been created successfully.
During creation the below error is appearing in the log viewer;
WCCILevent (0), 2019.04.26 13:49:34.942, PARAM,WARNING, 18, Value outside of alert ranges, DP: SSP:_mp_oglib_Y-LINK_IEC.alarm.Q_LINKERR:_original.._value, MAN: (SYS: 0 Event -num 0 CONN: 1)
Attached the example script for the reference;
R.Paramesh
AlertConfig Create.txt
(1.11 KiB) Downloaded 245 times
Re: Alert Config creation is giving error via script
In your first sentence you have written "ried to create the Non binary alert handling config for the binary DPE".
Are you using a binary DPE or not?
Why aren't you using a binary alert handling if it is a binary DPE?
