Report View with ULC license at Client side
VictorCalvo
Post by VictorCalvo »
I have a server with 3.15 WinCC OA version. The server has only ULC license, so I'm running the ui through a browser at the client side. The problem comes when I try to open a view report on the web browser. The goal is to open the report view at the client side, since is there where the ui is active. However, I'm not able to achieve that. As I'm using an ULC license, I cannot use the openUrl() function (the log file indicates that is not supported) and if I use the system() function to launch the explorer with the report URL, it opens on the server side. How can I launch the web browser so the report view will be displayed at the client side?
Thank you
Re: Report View with ULC license at Client side
When using ULC UX you cannot start applications at the client machine where the ULC UX is displayed. Also it is not possible to access files located on the client machine.
It is prohibited due to security reasons.
