Ascii Export
paramesh1985
Ascii Export
Post by paramesh1985 »
I have exported the specific dptype ".dpl" file via command prompt using the below command;
"C:\Siemens\Automation\WinCC_OA\3.15\bin>WCCOAascii.exe -proj ProjName -filter T -filterDpType DPTypeName -out D:\Projects\V315\Ewo\dplist\test.dpl"
dpl file is exported but the reference dptype information is missing in the dpl file.
how to pass the reference dptype syntax in the filter.
regards,
r.parameshwaran.
Re: Ascii Export
There is no command line option available to export also referenced dp types.
If this option is chosen in the ASCII manager panel the CTRL code in the panel reads the information for the referenced types and adds them to the DPT filter.
