WinCC OA V3.15 P0015.
1) Create a primitive text (Any entered text will do) and place on a Panel.
2) Double click the text to enable the text to be edited.
3) Highlight the text,
4) Click and hold mouse over the text.
5) Drag the mouse away from the text while holding down the mouse.
This crashes the GEDI User Interface, causing it to not respond.
While not a major problem, it's became a annoying bug within my team developing Mimics.
Dragging Primitive Text crashes Gedi UI
Re: Dragging Primitive Text crashes Gedi UI
I have tested and I can reproduce the problem in WinCC OA 3.15 after doing the operation several times. It did not occur at the first try.
When using WinCC OA 3.16 the problem does not occur.
As it is already fixed in the current version I will not forward this issue to our development department.
