loginConfigFileUser doesn't work
MrKintaro
Post by MrKintaro »
I have tried the following config file:
[general]
pvss_path ="C:\Siemens\Automation\WinCC_OA\3.16\"
proj_path ="C:\WinCC_OA_Proj\GettingStarted_3.16"
proj_version ="3.16"
langs = "de_AT.utf8"
langs = "en_US.utf8"
langs = "ru_RU.utf8"
lang = "auto"
paramLang = "en_US.utf8"
userName="root"
password=""
[ui]
loginConfigFileUser = 1
but the login panel doesn't fill the username and password.
Any suggestion or something wrong? I have also tried with other user like guest, no result
schneebergera
Re: loginConfigFileUser doesn't work
Post by schneebergera »
"paramLang" is not used anymore within version 3.16.
If you want to apply an userName you have to assign a password, too.
e.g. password = ""
with best regards,
MrKintaro
Post by MrKintaro »
Yes I know. It is the config of the demo in winccoa 3.16 not my fault.
please look the full code. I put also :
userName="root"
password=""
[ui]
I checked the code.
In the new login panels this functionality is not supported. I have informed our development department that the functionality is missing.
