TIA V15.1 compatibility
Smiffy
Post by Smiffy »
I am having issues loading in the exported SCADA file from V15.1 of TIA Portal.
OA sees the file but shows no tags within it and obviously will not import it.
I would attach the exort file, but there seems to be no way of uploading files to this forum that I can see.
Re: TIA V15.1 compatibility
Which WinCC OA version are you using in this project?
Probably it is easier to help you if you get in contact with the common WinCC OA Support using the Siemens Industry Portal.
When you want to get in contact with the official Siemens Support you can have a look at the following Knowledge Base entries:
https://www.winccoa.com/knowledge-base/ ... 9f8a0d9a98
https://www.winccoa.com/knowledge-base/ ... d7ae6b1eb4
Smiffy
Post by Smiffy »
Using V3.16 Update 6, which I believe is the latest.
The newest patch for WinCC OA 3.16 is patch P007.
Smiffy
Post by Smiffy »
OK I'll give that a try.
Thanks.
Smiffy
Post by Smiffy »
Thanks everybody, patch 7 worked.
