Not able to save the automatic created panel in the defined storage path
paramesh1985
Post by paramesh1985 »
HI,
I have created the multiple panels using the function "CreatePanel" . Function is working fine no issue on that.
Newly created all the panels are storing into the main project panel root directory only.
Not possible to create the panel under specific panel folder location or sub project folder location .
Is there any other function is available for that.
R.Paramesh
Re: Not able to save the automatic created panel in the defined storage path
If you define a relative path for the filename, e.g. vision/new.pnl the panel "new.pnl" will be created in the "vision" folder of the project.
Saving a panel in a sub project is not possible, new files are only created in the project directory.
