SNMP agent configuration mask cannot handle 5-digit port numbers
fandersen
Post by fandersen »
Hi ETM,
I am using WinCC OA 3.14 Upd 22.
For a customer, I had to change the configuration of an existing SNMP agent in WinCC OA. I ended up configuring the new port number using PARA since the configuration mask only allows 4-digit numbers.
Can you please fix this for all supported versions?
BR/Florian
Re: SNMP agent configuration mask cannot handle 5-digit port numbers
I have tested it with WinCC OA 3.16 and compared the panels with version 3.14 and 3.15.
It looks like the panels have been changed in 3.15 and defining port numbers with 5 digits is possible when using 3.15 or 3.16.
