I'd like to pass a variable to a dollar-parameter of a child panel. Usually I pass through a value or a dollar-parameter coming from a top panel but in this case I'd like to pass the value of a variable I have defined in the init script of the panel.
I tried the function setDollarParams() but it could not be used in this context.
Cheers,
Sebastien
Dollar-parameter: passing through a variable and not a value
- sblancha
Re: Dollar-parameter: passing through a variable and not a value
I do not unterstand what you want to do.
If you open a panel you can pass information to the panel using $-parameters.
Do you want to set the value for a $-parameter in the Initialize script of the panel which is opened?
- sblancha
I have a panel A. Inside panel A I have a panel B with $-parameter. I don't want to hard-code value of $-parameter of panel B. I want somehow that the init script of panel A set the value of $-parameter of panel B. Am I clear enough?
What is meant with "inside panel A"?
Is panel B loaded/inserted as reference in panel A?
- sblancha
Yes
Yes
If the value defined for the $-parameter is not static you can use the function addSymbol() to load the reference during runtime instead of adding the reference to the panel in GEDI.
- sblancha
Yes addSymbol() do the job.
Thank you.
Sebastien
Thank you.
Sebastien
