Windows 10 Scaling, Device Manager window Cut off
dano3829
Post by dano3829 »
Hi
I noticed that running Windows 10 with a scaling other than 100% causes the Device Manager in GEDI window not to size correctly. Winds up cut off.
Just curious if people just usually run 100% scaling or if there is a way for ETM to autodetect Scaling from Windows. I need to do some reading myself to understand why Microsoft has both resolution and scaling now in Win10.
Thanks,
Dan
Re: Windows 10 Scaling, Device Manager window Cut off
I have tested it. It only occurs when opening the panel from the Menu in GEDI.
If you open it from the System Management the panel is displayed correctly.
dano3829
Post by dano3829 »
Great thanks for the Tip!
