• Page 1 of 1
Balewski
HTTPS (SSL connection)
Postby Balewski »
Hi.
I am trying to establish a https connection to my serwer and i found this in the help:
Import the received certificate to the main keystore: bin\keytool -import -file <path to file> -keystore lib\security\cacerts -alias WinCC OA -storepass xxxx
The text you have copied describes how to load the certificate into the keystore.
If you just want to start a HTTP server in control using https there is no need to execute these steps. You just have to define the https port when starting the CTRL function.
