i´m using some reference panels whose Initialize event are by default not to be run. (Stat Init-Script in Ref=FALSE)
However I would like to initilize them after some time if some conditions are fullfilled.
How can I run the "EventInitialize" of this reference panels from the main panel? is there any possibilty to run it by code, like PANEL_SHAPE1.init() ??
Initliaze after "Start Init-Script in Ref"=FALSE
- alaralum
Re: Initliaze after "Start Init-Script in Ref"=FALSE
It looks like there is no option to start the Initialize scripts for a reference by command if the option Start Init-Script in Ref = FALSE..
You can maybe use another solution to load the reference with the function addSymbol() when the conditions are fulfilled.
