Good morning,
customer want to evaluate the different server solution above.
Do you have some documents where are highlighted the benefits of both solutions.
Regards.
License server vs Dongle server (WinCCOA 3.16)
- orla090978
Re: License server vs Dongle server (WinCCOA 3.16)
Can you please describe more accurate what the questions are.
What is a license server in that case?
Which operating systems are you using and are you using virtual machines?
- orla090978
Thanks for reply.
Sorry but I forget to add a premise: we are writing the specifications about this project and customer want to add in SCADA architecture also license server; we are not able to decide if is better a "License server" or "Dongle server" solution for WinCCOA licensing product purpose.
However I suppose the different solutios as following:
License server could be a phisyc machine (no VM) with Windows operating system (version will defined later).
Dongle server could be a SEH USB dongles mentioned in your Knowledge base.
Have you some suggestions or documnetation for both solutions?
Which solution for you is more reliable for costumer (security is a mandatory topic in our project).
Best regards.
Best regards.
In WinCC OA you can use the following possibilities for the licenses. A license is always the combination of a hardware code and a shield.txt file (license file):
-- Hardware based licensing
The hardware code is read from the hardware.
On the machine for the WinCC OA server project only the license file is installed.
-- Dongle based license
The hardware code is read from a Wibu Key dongle.
On the machine for the WinCC OA server project the dongle and the license file is installed
-- SEH dongle server
The hardware information is provided by the dongle server.
On the machine for the WinCC OA server project the license file is installed.
If you have additional questions it is maybe useful to get in contact with your common WinCC OA sales or support contact.
